AAA Authentication - Please Help! 🙏
msrbelfast
Hi, I'm hoping someone out there can help me before my head disintegrates!
I have this Packet Tracer file, link below, that has a (probably very slight) error with the AAA configuration... but I haven't a scooby-doo what the problem is. I'm literally on the floor begging you, but not in a way that I'll loose my job or anything, or see the kids starve... I don't work in this industry. It's just doing my head in.
https://drive.google.com/file/d/1td0ZOYNUjWLsE08Z_RO4cYaVyLvjgEHv/view?usp=sharing
Hi @msrbelfast
 Hope you have you head on yet.
I manage to make it to work with small chaning. Actually I fixed the SW2 only but I believe you can move forward with the rest.
On the below command you was using the switch IP address while you should use the TACACS IP address
tacacs-server host 192.168.10.2 key ciscosecret
The line in the begining of the configuration
aaa authentication login telnet_lines group tacacs+
must reflect the line at the end of the configuration
line vty 0 4
login authentication telnet_lines
Last but not least, the configuration on the server side must be TACACS and not radius.
