08-10-2013 01:41 AM
Hello All,
I am trying to figure out how aaa authorization with tacacs+ works.
I am totally comfortable with aaa authentication..But am not able to understand how it works...How diff priv levels are assigned to diff users?..
I am totally freaked out...
08-10-2013 01:47 AM
how can we apply diff priv levels for diff users using AAA authorization?
08-10-2013 07:56 AM
The device side side setup is pretty simple. You just use the aaa authorization command set. A good bit of the setup is on the ACS server end.
Cisco has a pretty thorough configuration example posted here.
