About NX-OS and IOS-XE Default Licensing
Suzukikoki
I would like to ask a question about the license.
I would like to check if the following devices and licenses are installed by default.
There is no description in the data sheet, and I cannot understand it even with the show command of the actual machine.
If the license is not the default license, you will need to replace the license when performing maintenance replacement.
I need to figure it out. Does anyone know?
■N9K(NX-OS) System version: 9.3(8)
・LAN_ENTERPRISE_SERVICES_PKG(LAN license for Nexus 9300-XF)
■N3K(NX-OS) System version: 9.3(8)
・LAN_BASE_SERVICES_PKG
■ASR1001-X(IOS-XE) Version 17.3.6
・adventerprise
・interface_10g
・ipsec
0 Replies 0
