ACC-3650 | copy flash:TAC_memory_monitoring.txt usbflash0 cannot copy
rindika7966
Im trying to copy the below file, but it dosent copy to USB.
25 Replies 25
Leo Laohoo
What is the exact error message?
The syntax is incorrect.  Please copy-and-paste the command below:
copy flash:TAC_memory_monitoring.txt usbflash0:
WHQ21FRK1-ACC-3650-1#copy flash:TAC_memory_monitoring.txt usbflash0
Destination filename [usbflash0]?
Copy in progress...CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
3455964 bytes copied in 0.714 secs (4840286 bytes/sec)
but when I check USB no any files copied to usb
also I changed 2, 3 USB drives, also same for them
ok thanks I;ll try and update
WHQ21FRK1-ACC-3650-1#copy flash:TAC_memory_monitoring.txt usbflash0:
Destination filename []?
?File name not specified
%Error parsing filename (Bad file number)
Try this:
copy flash:TAC_memory_monitoring.txt usbflash0:TAC_memory_monitoring.txt
Destination filename [TAC_memory_monitoring.txt]?
%Error opening usbflash0:/TAC_memory_monitoring.txt (No such file or
directory)
Let's try a little test:
copy flash:TAC_memory_monitoring.txt flash:monitoring.txt
Post the complete output to the follow-up command:
dir flash:*monitoring*.txt
what is the USB drive format (FAT16/32) ?
NTFS
Hello, try FAT32...does that make a difference ?
 I tried both. no deference
rindika7966
hi good morning any update ?
I am waiting for the output I've requested.
WHQ21FRK1-ACC-3650-1#copy flash:TAC_memory_monitoring.txt flash:monitoring.txt
Destination filename [monitoring.txt]?
Copy in progress...CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
18703101 bytes copied in 3.925 secs (4765121 bytes/sec)
WHQ21FRK1-ACC-3650-1#dir flash:*monitoring*.txt
Directory of flash:/*monitoring*.txt
85186  -rw-    18703101  May 27 2024 12:00:51 +03:00  TAC_memory_monitoring.txt
85204  -rw-    18703101  May 27 2024 12:44:50 +03:00  monitoring.txt
1621966848 bytes total (892682240 bytes free)
WHQ21FRK1-ACC-3650-1#Connection to 172.16.253.25 closed by remote host.
Connection to 172.16.253.25 closed.
[rindika@height8 ~]$
