NetFlow Terms
1pgordo
Frequent Visitor
Frequent Visitor
im getting into NetFlow and I want to know if I understand the flow record correctly.Flow record: The Flow record is used to specify different flows to be matched and which data is collected from them. The match statement: The match statement is used to match on a packet field.
Ruben Cocheno
@1pgordo
For Netflow it is used like this: The Flow record is used to specify different flows to be matched and which data is collected from them. The match statement is used to match on a packet field
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Torbjørn
Hi @1pgordo, That is correct.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Ruben Cocheno
@1pgordo
