Access server not displaying ROMMON mode target device
mgroof
Hi All,
I'm encountering a curious problem (or I'm overlooking something).
I'm configuring a console server for configuring remote devices. This is working well except for the fact that if a target device is in ROMMON mode, the console server refuses to displays the target device console. It does open the connection but the ROMMON prompt is not shown on the console server . This is essential for this device as we will need to use it to reset passwords remotely and thus need to be able to access ROMMON mode from the console server.
Parts used are a 2951 router and a HWIC-8A serial card. Does anyone has some ideas?
Posted my config below:
[code]
Current configuration : 4389 bytes
! Last configuration change at 04:19:45 UTC Wed Sep 19 2012
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip host Chassis1 2002 100.0.0.1
ip host Chassis2 2003 100.0.0.1
ip host Chassis3 2004 100.0.0.1
ip host Chassis4 2005 100.0.0.1
ip host Chassis5 2006 100.0.0.1
ip host Chassis6 2007 100.0.0.1
ip host Chassis7 2008 100.0.0.1
ip host Chassis8 2009 100.0.0.1
ip cef
license udi pid CISCO2951/K9 sn FCZ13507226
hw-module sm 1
redundancy
interface Loopback0
 ip address 100.0.0.1 255.255.255.255
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet1/0
 no ip address
 shutdown
interface GigabitEthernet1/1
 description Internal switch interface connected to EtherSwitch Service Module
 no ip address
interface Vlan1
 no ip address
interface Async0/0/0
 no ip address
 encapsulation slip
interface Async0/0/1
 no ip address
 encapsulation slip
interface Async0/0/2
 no ip address
 encapsulation slip
interface Async0/0/3
 no ip address
 encapsulation slip
interface Async0/0/4
 no ip address
 encapsulation slip
interface Async0/0/5
 no ip address
 encapsulation slip
interface Async0/0/6
 no ip address
 encapsulation slip
interface Async0/0/7
 no ip address
 encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
menu TS title ^C
Virtual Lab Terminal Server
To exit from a device, use CTRL+SHIFT+6 then press x
^C
menu TS prompt ^C Your selection : ^C
menu TS text 1 Connect to Rack1 - Chassis1
menu TS command 1 resume Chassis1 /connect telnet Chassis1
menu TS text 2 Connect to Rack1 - Chassis2
menu TS command 2 resume Chassis2 /connect telnet Chassis2
menu TS text 3 Connect to Rack1 - Chassis3
menu TS command 3 resume Chassis3 /connect telnet Chassis3
menu TS text 4 Connect to Rack1 - Chassis4
menu TS command 4 resume Chassis4 /connect telnet Chassis4
menu TS text 5 Connect to Rack1 - Chassis5
menu TS command 5 resume Chassis5 /connect telnet Chassis5
menu TS text 6 Connect to Rack1 - Chassis6
menu TS command 6 resume Chassis6 /connect telnet Chassis6
menu TS text 7 Connect to Rack1 - Chassis7
menu TS command 7 resume Chassis7 /connect telnet Chassis7
menu TS text 8 Connect to Rack1 - Chassis8
menu TS command 8 resume Chassis8 /connect telnet Chassis8
menu TS text s show all established sessions
menu TS command s show sessions
menu TS options s pause
menu TS text c<no> clear the session by number ie: c5
menu TS text e menu-exit
menu TS command e menu-exit
menu TS text q Quit terminal server session
menu TS command q exit
menu TS command c1 c1
menu TS command c2 c2
menu TS command c3 c3
menu TS command c4 c4
menu TS command c5 c5
menu TS command c6 c6
menu TS command c7 c7
menu TS command c8 c8
menu TS clear-screen
menu TS line-mode
control-plane
alias exec c1 disconnect Chassis1
alias exec c2 disconnect Chassis2
alias exec c3 disconnect Chassis3
alias exec c4 disconnect Chassis4
alias exec c5 disconnect Chassis5
alias exec c6 disconnect Chassis6
alias exec c7 disconnect Chassis7
alias exec c8 disconnect Chassis8
line con 0
 transport output all
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 0/0/0 0/0/7
 exec-timeout 0 0
 no exec
 transport input all
 transport output none
 stopbits 1
 flowcontrol hardware
line 67
 no exec
 transport input all
 stopbits 1
 flowcontrol software
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Router#
[/code]
mgroof
This appeared to be a hardware issue and is solved. Configuration of the access server was o.k..
