ACE Entry format for a loopback Address
Drew15
I'm trying to make an ACE in an extended ACL  for my loop back address and also for my management VLAN
I'm creating and access for an access list that when applied will be 'in"
I'm not sure of the formatting. This is what I wrote (see below). Is this proper formatting or should it be modified?
Loopback IP is:  20.200.255.251
permit any host 20.200.255.251 << (loop back address)>> 20.200.255.251
Management VLAN IP:  20.200.254.0 255.255.255.0
permit any host 20.200.254.0  0.0.255 cant figure out this next part.
Thank you.
The syntax of this is correct, but whether "any" should be first or second depends on how the acl is applied.
The syntax of this is not correct. You can not specify both "host" and 0.0.0.255. And in this case since you are referencing a subnet you should not use host.
Rick
7 Replies 7
ACL IN direction is not effect traffic direct to interface
it effect traffic that pass through this interface
Thank you. I think I understand.  There is no need to address a loop back address or VLAN IP space since they will not be going out the port I will be applying the Access List to.  Is my understanding correct?
If you meaning that the ACL to deny VLAN IP is not Need if the ACL config under same VLAN then Yes, it have no effect at all.
instead check from where this packet enter the SW and apply ACL in that interface not under VLAN interface.
I am glad that our suggestions have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
Joseph W. Doherty
Unclear exactly what you're trying to accomplish.
Possibly part of your confusion might be due to using "host" which is a descriptive way to provide a mask of 0.0.0.0.  Also "any" is a descriptive way for a mask of 255.255.255.255 and where IP came be any number usually shown as IP 0.0.0.0.
I.e. host 1.1.1.1 same as 1.1.1.1 0.0.0.0
and
Any same as #.#.#.# 255.255.255.255
Lastly, if you can clarify want you want to accomplish between your loopback interface and your VLAN network, might be able to help further.
Rick
Just to clarify what Rick describes,
Is still incorrect (syntax).  It might be like:
Or
permit ip host 20.200.255.251 20.200.254.0 0.0.255
Or
permit ip any 20.200.254.0 0.0.255
NB, above shows correct syntax, correct ACE depends on what you're trying to do and also what interface it's applied on and whether in or out.
PS, edit: NB: I believe I "misread/misunderstood" Rick's post (my bad).  I believe he intended reader to understand he's saying "permit any host 20.200.255.251" is correct syntax usage (and it is, except for other than missing kind of [protocol, e.g. "IP", "TCP", etc. after permit]) packets and that "permit ip any host 20.200.255.251" is incorrect syntax usage (ditto missing kind of protocol parameter).  (My apologies to both @Richard Burts and anyone else I may have confused!  (Rick certainly knows the correct syntax for what he is describing.)
