ACS 4.2 GUI Username and password
I have setup cisco acs 4.2.1 i windows swerver 2008 and want to access through GUI, GUI interface is appear but I don't know the default  usrname and password. Please help.
HI Hossain,
If u clicked locally means:
u must http://localhost:2002  logon locally on which u installed ACS.
u must use one of these HTML browsers:
•Microsoft Internet Explorer 6 Service Pack 1 and 5.5 for Windows-English and Japanese versions
•Microsoft Internet Explorer 7 Service Pack 2 for Windows Server 2003 and Service Pack 2 for Windows XP
•Mozilla Firefox 2.0 and 2.0.0.6
•Netscape Web Browser 7.0, 7.1, and 7.2 for Windows-English and Japanese versions1
Did u foloowed these steps:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/installation/guide/windows/install.html
9 Replies 9
Sandeep Choudhary
Hi Sandeep choudhary,
Thanks for your reply. I am unable to login using your provided credential. username admin and password--> Password or --> password both i have used but no luck.
HI Hossain,
Can u try these:
If its ur first time then :
Username: acsadmin
Password: default
After this the server will ask you to change the password. Please give it a try and let me know how it goes.
Reset ACSAdmin Password: To reset the password of the default GUI admin, use the acs reset-password command from the EXEC mode.
http://www.ciscopress.com/articles/article.asp?p=1671906&seqNum=7
Dont forget to rate helpful posts.
I have tried using the below but same result.
Username: acsadmin
Password: default
Hi Hossain,
so lets find out the exact issue:
Which option did you click (checkbox), windows authentication or local
ACS only while installing ACS?
If u clicked locally then u may need to logon locally to the box first and create an ACS
account.
After installation, I believe you need to use http://127.0.0.1:2002 from the
device CSACS is installed on.
After that, I think you are prompted to setup a local username and
password for administration.
Try using the loopback address, and read the interface carefully for and
guidance on the creation of an admin account.
During the setup i selected "check the ACS internal database only" radio button and finally automatic run http://127.0.0.1:2002 in IE.
HI Hossain,
After using Mozilla Firefox 2.0.0.6 and http://localhost:2002,
Now its working. Many thanks for your help. Previously i was tried from my remote machine.
Hi Hossain,
Glad that u resolved ur issue.
Thanks for rating.
Reagrds
Dont forget to rate all helpful posts.
