Prime Creation device failed, IP addres is not unique
v.slavov
Hi!
When i try add new device in Prime 1.3 I get the following message:
Add Device xx.xx.xx.xx Creation Failed. IP Address is not unique. Address exist as an interface-INVENTORY_SERVICE_110
but this address *is unique*, this address is not exist in Prime. I have no interface or device with this address in Prime.
I read logs, but i did not find anything there.
Somebody had the same problem? How i can resolve it?
Richard Muhr
I am also getting this error, I deleted this device and was attempting to re-add it.  I am assuming that delete of the device out of the database was not clean.  Any ideas on how to locate the entry and delete it?
I am also getting this error. Did you managed to solve it?
Jelena
Sometime I had the same problem. The device I was trying to add to Prime was already added
through another ip address, which was discovered through a process of automatic discovery. In my case corresponded to a loopback IP. Try searching your device by its MAC address.
Regards.-
Thank you for your answer.
Can you please suggest me where I should search MAC address of devices in Prime (I was unable to find that filter in gui)?
Jelena
