ACS 5.8 admin authentication with multiple AD
Dorian
We currently have an ACS in version 5.8 mapped to an Active Directory and used to authenticate the admins when they want to login to the Cisco switches/routers to manage them.
Admins will have new accounts for admin tasks but theses accounts will be in a different Active Directory.
I would like to know if it is possible to map the ACS with another Active Directory and still keep the first Active Directory mapping working ? So that everybody can still manage the equipments even if they don't have their new account.
I want authentication with admin accounts from the old Active Directory and the new one to work in parallel.
Thanks a lot.
Dorian
5 Replies 5
pieterh
the documentation is not very clear.
Note If multiple join operations are performed, multiple machine accounts are maintained inside ACS, one for each join operation.
(table 8-11) could mean you can join multiple AD,
or it could mean it does not detect "allready joined" and joins again with a new created machine account
this link says 5.3 cannot!
found this:
Joining ACS to an AD Domain
You can join the ACS nodes from same deployment to different AD domains that has two way trust between each other. However, each node can be joined to a single AD domain. The policy definitions of those ACS nodes are not changed and that uses the same AD identity store.
indivudual nodes within a ACS deployment can join another domain within a trusted domain structure (AD).
so this comes down to NO you cannot really join multiple AD's
thanks for your reply pieterh.
What about adding another LDAP in the External Identity Stores menu and then adding a rule in the Group Mapping of the current Access Services used for admin authentication to devices. The compound conditions of this new rule would match the new LDAP and be placed after the current rule that matches the current Active Directory.
Could that work ?
Dorian
using LDAP would be no problem
Multiple LDAP Instances
You can create more than one LDAP instance in ACS 5.8. By creating more than one LDAP instance with different IP address or port settings, you can configure ACS to authenticate by using different LDAP servers or different databases on the same LDAP server.
Ok thank you very much pieterh
