ACS database not replicating
daven.delidle
Community Member
Greetings,
We have two cisco secure databases running in geographically diverse areas. for some reason the "master" database will not replicate to the "slave" the error I get is just "outbound database replication failed refer to CSAuthlog file" the CSAuthlog file isn't much help either. I have tried reboting the box & stopping and restarting services but no luck. any ideas?
Thanks in advance.
jreekers
Level 8
Level 8
Hi. You don't mention what version of CS you are running and on what platform (Windows or Solaris), but there is a known bug...CSCeh84997...that you may be hitting. Here are the details of the Release Notes:
The following error may be generated by the ACS appliance or ACS Windows
server after a database replication.
Database Replication.csv file:
ERROR Outbound database replication failed - refer to CSAuth log file
CSAuth log file:
CSBackupRestore(OUT) Failed to create output directory C:\Program
Files\CiscoSecure ACS v3.3\CSAuth\DbSyncScratch\\RegValues for DLL
Conditions:
The target folder on the replication slave machine already exists.
Workaround:
Delete the target folder
efairbanks
Level 3
Level 3
I am getting the same error.
jreekers
Level 8
Level 8
CSAuth log file:
Conditions:
Workaround:
