NAM2
tmesbah
Level 4
Level 4
Just bought and installed NAM2 "ver 3.4(1a) but I am having problem ping it after configuring IP address, default Gateway.
The problem is NAM showed that it is in vlan 1 and my Catalyst 6500 is in vlan 33. when trying to set NAM 2 port to vlan 33, I get an error saying "this feature is not supported. Not added to vlan".
Any idea
6 Replies 6
David Stanford
If you run a show tech on the NAM itself are you seeing any errors with relation to Falcon?
The only errors I see when running sh tec on the NAM are:
May 18 10:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 11:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 12:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 13:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 14:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 15:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 16:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 17:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 18:09:50 localhost config_monitor: 2006 May 18 18:09:50 UTC +0000: %NAM-5
-CONFIG_CHANGE: Configuration changed
May 18 18:12:50 localhost config_monitor: 2006 May 18 18:12:50 UTC +0000: %NAM-5
May 18 18:15:50 localhost config_monitor: 2006 May 18 18:15:50 UTC +0000: %NAM-5
May 18 18:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 19:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 20:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 21:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 22:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 18 23:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 19 00:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 19 01:55:24 localhost rmond[708]: Falcon: not getting any packets!
May 19 02:55:24 localhost rmond[708]: Falcon: not getting any packets!
Is your 6509 running CatOS or IOS? If CatOS may be similar to something I saw before, checking now
Thanks Davistan. It is CatOS.
Worked now after doing :
1) reset 9 cf:1
wait until the NAM come the back
BC65M40-01> (enable) sh port 9
* = Configured MAC Address
Port Name Status Vlan Duplex Speed Type
9/1 disable 1 full 1000 Net Analysis
9/2 NAM2 connected 33 full 1000 Net Analysis
9/3 disable 1 full 1000 Net Analysis
9/4 disable 1 full 1000 Net Analysis
9/5 disable 1 full 1000 Net Analysis
9/6 disable 1 full 1000 Net Analysis
9/7 connected trunk full 1000 Net Analysis
9/8 connected trunk full 1000 Net Analysis
BC65M40-01> (enable) ping 142.206.33.131
2) reset 9
rmushtaq
Level 11
Level 11
Devices running CatOS do not need to configure a VLAN as the NAM management port. The port is automatically synchronized to the VLAN assigned to interface sc0 on the Supervisor engine.
