ACS Setup with Ciscoworks
xayavongp
I have ACS 3.2.  I was able to create the ACS Login Module for Ciscoworks (2.6) fine.
However I am having trouble assigning privileges to users or groups [already in ACS].
It says to scroll down to Ciscoworks under Group Edit Settings and in User settings as well.
Where is this Ciscoworks portion the document talks about ?  It is suppose to populate the ACS automatically?
Pete
pvanvuuren
Level 3
Level 3
Hi Pete
although this document is for ACS ver4.1 and LMS 3.0 it is still valid and applicable for you setup. https://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html
And yes, LMS is suppoed to register its modules in ACS and is vissible through the " shared profile components "option. If it isn't listed there, then you you need to rerun the integration steps.
P
