SNMP OID for IP NAT translations
victor_87
I am looking for the SNMP OID to monitor the sh ip nat translations on a cisco 6500.
Can anyone please know if this is available.
Victor
7 Replies 7
Joe Clarke
What version of IOS is this switch running?
The IOS version is 12.2
===> 122-18.SXF14.
I need to see the "show version" output.
hi Joe,
Sh ver below
Cisco IOS Software, s3223_rp Software (s3223_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXH4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sun 09-Nov-08 23:57 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
System returned to ROM by s/w reset  EDT (SP by power-on)
System restarted at 01:43:21 EDT
System image file is "sup-bootdisk:s3223-ipservicesk9_wan-mz.122-33.SXH4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6506-E (R7000) processor (revision 1.0) with 458752K/65536K bytes of memory.
Processor board ID
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
22 Virtual Ethernet interfaces
49 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
This image does not support the CISCO-IETF-NAT-MIB which provides details about active translations.
Thanks Joe,
Please tell me which image supports the MIB, will plan on Upgrading if required.
Victor
This MIB is not supported for your platform.  I had thought it was, but there was a glitch with the MIB Locator.  For a complete list of supported platforms and images see http://tools.cisco.com/ITDIT/MIBS/AdvancedSearch?ReleaseSel=0&PlatformSel=0&fsSel=0&mibIdArr=250009&totalPages=1&totalNoOfImages=-1&pgSelect=1
