Showing results forĀ
Search instead forĀ
Did you mean:Ā
Adding a folder to ciscoworks drive utilization?
adriannims
In LMS 4.0 under Admin->System, in the Ciscoworks drive utilization I have 2 drives/folders: /opt/CSCOpx and /var/adm/CSCOpx and it very nicely shows me the utilization in procentages.
Is it passible to add another, a third drive/folder: /CSCOpx_logs/. This  folder is on a separate drive than the other 2 and I will be bvery interested to see the drive utilization on that one because it is there where my syslog is putting all the syslog information from my devices. Kindly please advise.
Joe Clarke
No.  The monitored directories are determined dynamically based on where LMS is installed (in addition to /tmp and /var).
