Adding devices to existing community Network Assistant
Jkisler99
Just starting to use Cisco's Network Assistant but i cant figure out how to add more switches to an existing community.
Whats the best way to add more devices to a already existing Community?
Version: 6.3
Thanks in advanced!
Marvin Rhoads
There are two ways, depending on whether it's on your topology view already as a neighbor. If it's not then:
1. Application > Communities > select the Community you wish to add switch to and then > Modify. In the resultant window discover it/them by IP address or range.
...otherwise then:
2. If it's already a neighbor of an existing community member, right click it in the Topology view and select "Add to Community".
Marvin Rhoads
...otherwise then:
