01-12-2018 05:15 AM - edited 03-01-2019 06:20 PM
Currently, I am working on Cisco Prime Infrastructure 2.2. I have around 20 remote stations that are connected to the core switch through SDH.
In topology, I am assigning Links manually and interfaces as well. Is it possible that I can assign One port say (GigabitEthernet1/23) of Core switch to one port (GigabitEthernet1/1/3) of all 20 stations?
Is there any way to do so?
NA
01-12-2018 06:03 AM
I don't think it will allow it unless it is sub-interfaced. What you could do is create a cloud attach all the devices to the cloud and then attach the cloud to the Core Switch.
It would be clean as well as you can label the cloud SDH.
01-12-2018 07:40 AM
Thanks Andrew for your reply.
You mean I can create an unmanaged Network and Asssign those switches to it. and then I can link that Network with Core Switch.
in this way all the alarms will work normally?
02-02-2018 06:57 AM
Hi Andrew,
I applied your suggestion and it is working fine.
I am facing one more issue that is I am getting alarm 'Authentication Request failed from 10.175.1.254'.
Where 10.175.1.254 is the IP Address of the NMS server.
NA
