Addressing and NAT for 3rd Party Router using ISP subnet
ccisco630
Background:  ISP gave me a /29 and an audio/visual vendor has a router they need assigned an IP within that subnet so they can connect remotely.  I am using a 4431 for my network and have an open interface and would like to hang the A/V router to my 4431.  How would I NAT the A/V router so that it uses one of my public IP's but does not overlap with my outside facing interface on the 4431?  A/V router public IP 142.154.xxx.19 /29 and private IP I would like to use 192.168.60.5 /24.  I also want to only allow that A/V vendor to get to their device and not my LAN, what ACL would prevent this?  Any suggestions are greatly appreciated!
balaji.bandi
Simple config to try as below
ip nat inside source static 192.168.60.5 142.154.xxx.19
BB
Thanks!  So say I connect the vendor's router to my 4431 int g0/0/3.  Do I give my int g0/0/3 a 192.168.60.0/24 address and their router will have 192.168.60.5 255.255.255.0 or will their router just have the static 142.154.xxx.19 assigned to whichever interface connects to my 4431?  I guess I'm confused on how the traffic from their router will get out, or does that NAT statement allow it through if I put ip nat inside on my g0/0/3 interface?
