Alarm Generation in cisco IOS XR - Logically
akshaypb6
Hi Team,
There is requirement to check whether the new Alarm monitoring System in the network is able to capture all the new alarms generated in the nodes.
For that we need to generate the alarms in the lab test node integrated with the alarm monitoring system and check whether the alarms are getting captured.
Kindly let me know if in case any of the following alarms can be made by the config changes in the nodes please.
1.isisDatabaseOverloaded
2.isisOwnLSPPurge
3.isisProtocolsSupportedMismatch
4.isisSequenceNumberSkip
5.Optical Alarm
6.PKT_INFRA-LINK-3-DOWN
7.RP-RED-LOST-NSRNR
8.SWT_AUTH_FAIL
9.cefcPowerStatusChange
10.ConfigArchive
Thanks in advance
use below link to get guide for this.
https://community.cisco.com/t5/xr-os-and-platforms/isis-adjacency-monitoring-under-ios-xr-4-3-1/td-p/2331557
you can use relevant SNMP OIDs to trap and monitor.
Good luck
KB
mark this solved or up vote if you got solved your concern
Good luck
KB
