ISIS adjacency monitoring under IOS-XR 4.3.1
scorpion
I need to monitor my entire networks ISIS adjancencies using SNMP Trap. But I am having some hard time figuring out the OID values. Can someone please help me figure out the OID's required for ISIS adjacency monitoring.
HW : Cisco 12416
SW : IOS XR 4.3.1
Thanks in advance.
dpothier
Ensure you have the isis traps you want enabled:
RP/0/8/CPU0:PR-GSR-1(config)#snmp-server traps isis ?
  adjacency-change                isisAdjacencyChange
  all                             Enable all IS-IS traps
  area-mismatch                   isisAreaMismatch
  attempt-to-exceed-max-sequence  isisAttemptToExceedMaxSequence
  authentication-failure          isisAuthenticationFailure
  authentication-type-failure     isisAuthenticationTypeFailure
  corrupted-lsp-detected          isisCorruptedLSPDetected
  database-overload               isisDatabaseOverload
  id-len-mismatch                 isisIDLenMismatch
  lsp-error-detected              isisLSPErrorDetected
  lsp-too-large-to-propagate      isisLSPTooLargeToPropagate
  manual-address-drops            isisManualAddressDrops
  max-area-addresses-mismatch     isisMaxAreaAddressesMismatch
  orig-lsp-buff-size-mismatch     isisOrigLSPBuffSizeMismatch
  own-lsp-purge                   isisOwnLSPPurge
  protocols-supported-mismatch    isisProtocolsSupportedMismatch
  rejected-adjacency              isisRejectedAdjacency
  sequence-number-skip            isisSequenceNumberSkip
  version-skew                    isisVersionSkew
RP/0/8/CPU0:PR-GSR-1(config)#snmp-server traps isis adjacency-change ?
You can view the supported MIB's per XR12K release here:
ftp://ftp.cisco.com/pub/mibs/supportlists/xr12000/xr12000-supportlist.html
We support the ISIS-MIB
ftp://ftp.cisco.com/pub/mibs/v2/ISIS-MIB.my
Refer to the isis adjacency table info:
-- The IS Adjacency Table
-- Each adjacency to an IS corresponds to one entry in this
-- table.
    isisISAdjTable OBJECT-TYPE
Full RFC4444 ISIS MIB support was added from 4.1.0 onwards. Prior to that it was partailly supported
You can map the OID's from the router to above ISIS-MIB.my file via CLI:
RP/0/8/CPU0:PR-GSR-1#show snmp mib object-name | inc ISAdj
Wed Sep 18 11:19:18.688 UTC
  1.3.6.1.2.1.138.1.6.1.1.2                 isisISAdjEntry.2
  1.3.6.1.2.1.138.1.6.1.1.3                 isisISAdjEntry.3
  1.3.6.1.2.1.138.1.6.1.1.4                 isisISAdjEntry.4
  1.3.6.1.2.1.138.1.6.1.1.5                 isisISAdjEntry.5
  1.3.6.1.2.1.138.1.6.1.1.6                 isisISAdjEntry.6
  1.3.6.1.2.1.138.1.6.1.1.7                 isisISAdjEntry.7
  1.3.6.1.2.1.138.1.6.1.1.8                 isisISAdjEntry.8
  1.3.6.1.2.1.138.1.6.1.1.9                 isisISAdjEntry.9
  1.3.6.1.2.1.138.1.6.1.1.10                isisISAdjEntry.10
  1.3.6.1.2.1.138.1.6.1.1.11                isisISAdjEntry.11
  1.3.6.1.2.1.138.1.6.2.1.2                 isisISAdjAreaAddrEntry.2
  1.3.6.1.2.1.138.1.6.3.1.2                 isisISAdjIPAddrEntry.2
  1.3.6.1.2.1.138.1.6.3.1.3                 isisISAdjIPAddrEntry.3
  1.3.6.1.2.1.138.1.6.4.1.1                 isisISAdjProtSuppEntry.1
regards,
david
dpothier
-- table.
regards,
david
Thanks for your reply.
show snmp mib object-name | inc ISAdj did the trick for me.
Happy networking.
