Alerts on interfaces I want to exclude - LMS 4.1
edgertonj
I have an inventory added to Ciscoworks and am getting alerts on interfaces that I want to exclude but for the life of me I can't figure out how to exclude interfaces. Any tips on how to exclude interfaces from the fault engine in 4.1 would be greatly appreciated!
Jason Edgerton
Marvin Rhoads
You need to change the polled interfaces per the following documentation instructions:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/monitoring_troubleshooting/mnt-fault.html#wp1586643
You can exclude any or all physical interfaces and/or IP addresses (excluding the address used to poll the system).
Hope this helps.
Marvin Rhoads
Hope this helps.
Thanks a bunch! A simple thing to be sure, but for some reason I was struggling trying to find it.
_
Jason
Jason,
You're welcome. Glad to be of assistance and thanks for the rating!
