alternative to wget and fetch
tinycore1
Dear all,
I'm trying to make an updatescript to update the public ip of the router.
I had following script:
kron policy-list update
cli tclsh http://myupdatelink
kron occurrence update in 1 recurring
policy-list update
This script however only runs once and then gets removed from the configuration file.
tinycore1
I've found a solution by using the ip sla command.
