ANI Server doesn't start
marekbudzisz
I have problem with ANIServer. I cannot start this service manually or automatic.
I have a message:
"ANIServer failed to start"
and in Ani-log:
"Informational: ANIServer starting Cisco Process Manager communication thread
ani ERROR AniLoadConfiguration: Failed to load mibs during initialization: java.lang.NullPointerException"
Additional: When I'm trying use UTUtility - all aplication in LMS Server hang up .
I solve this problem by restart server...until next using...
Marek
5 Replies 5
Joe Clarke
Please post your NMSROOT/campus/etc/cwsi/ANIServer.properties file.
My ANIServer.properties file :
EnablePurgeArchives=ON
PurgeArchivesOlderThan=180
EnablePurgeJobs=ON
PurgeJobsOlderThan=180
That's the whole file? Then it's very corrupt. First, shutdown Daemon Manager. Then, copy ANIServer.properties.orig to ANIServer.properties, then edit ANIServer.properties, and replace the line:
DEVICESROOT=.
With, for example:
DEVICESROOT=C:\\PROGRA~1\\CSCOpx\\campus\\lib\\classpath
Or, on Solaris:
DEVICESROOT=/opt/CSCOpx/campus/lib/classpath
Then, restart Daemon Manager. You will need to go back into the Campus Manager GUI, and reconfigure Data Collection, but ANIServer should now be started.
Thanks a lot
That was it:)
Hello
I did all what you mentioned but the ANIServer is still not working
Process= ANIServer
State  = Failed to run
Pid    = 0
RC     = -2
Signo  = 1073741822
Start  = N/A
Stop   = 3/8/2011 1:12:00 PM
Core   = Not applicable
Info   = Application failed or was registered incorrectly.
How can I solve this issue ?
