06-19-2006 02:03 PM
We recently re-deployed our CiscoWorks LMS2.2 server at a new location with a new server name. ANIServer appears to be "partially" working. Status indicates "running with busy flag set" and Campus Mgr. is able to discover devices. However, ServerConfiguration>Diagnostics>Discovery Metrics> states "ANI Server Not Running". Also ServerConfiguration>Diagnostics>Analyze ANI Server> shows "ERROR: An error occured communicating with your ANI Server [date/time]. ANI Server may not be running..." "ERROR RECEIVED - AniWrapper>>analyze(system) ServerNamed: ANIServer4.2-sestcwk1 on port 14004" "SystemInformation=unknown - ConfigurationSettings=unknown - RawAnalysis=unknown - Devices=unknown" Could these errors be caused by our renaming the CiscoWorks server? Is the new name confusing ANIServer somehow?
Thanks.
GPM
Solved! Go to Solution.
06-19-2006 05:29 PM
If you change the name of the server, you need to modify the PX_HOST entry as well in md.properties.
This is documented at the following location:
06-19-2006 05:29 PM
06-21-2006 01:00 PM
Thanks for the help. Problem solved.
