Ansible problems
rasmus.elmholt
Level 11
Level 11
I'm trying ansible for the first time and have meet some problems in getting the basics to work.
I have a simple playbook that runs a command and saves the output in a file, but it won't work.
ansible-playbook -vvvv playbooks/backup_cisco_router.yaml
Take a look at the attached files
rasmus.elmholt
Level 11
Level 11
installed ansible using the official documantation for Ubuntu and reindented all lines in the config file. That solved the problem.
rasmus.elmholt
Level 11
Level 11
