Any command to see login history using CLI
taoleiccie
Hello.
Without a syslog server, is it possible to check login history (when & who) by using CLI?
Thanks.
John Blakley
Yes and no. :-)
You can log to the router/switch using:
login on-success log
The problem with this is that it logs to the buffer which will eventually overwrite. I would suggest a syslog server if possible. And this line doesn't work if you're authenticating to a RADIUS or TACACS server, it only works if you're using local authentication.
HTH,
John
*please rate if helpful*
HTH, John *** Please rate all useful posts ***
