APs not showing in Network Topology - Prime Infrastructure 3.7
DavidLewis79672
I have added some new APs to PI 3.7 and they are listed under Inventory>Device Management>Network Devices, but they do not show in Maps>Topology Maps>Network Topology. I have tried to add the APs to a group / site in  Inventory>Device Management>Network Devices but I receive an error message - "Add: operation failed. Adding to group failed: 1 Access point(s) can't be added to Campus." Can anyone explain what I am doing wrong please?
7 Replies 7
Mark Elsen
       - Are the access point (models) supported by your current version of Prime Infrastructure ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
We already over one hundred of this model AP in PI that show up in topology.
 - Use latest patch + device pack  for  PI3.7 , if that does not help consider upgrading Prime.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
can you add the devices to a new (pre-defined or custom) device group through 'Inventory > Group Management > Network Device Groups' ?
I have just tried using - 'Inventory > Group Management > Network Device Groups' to add the APs to a group. Unfortunately this also fails.
what (if any) is the difference between the APs that do show up in the topology, and those that do not ? I am thinking of CDP, Flexconnect, IOS version, etc...
I as far as I can see the configuration is identical including CDP, Flexconnect and IOS version.
