Identify if LLDP is enabled, using SNMP
Im looking for a way to identify if a device is LLDP enabled, using SNMP. There's 2 scenarios in my case.
1. LLDP is enabled, but no neighbors are available(for some reasons)
#show lldp neighbors
Capability codes:
(R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
(W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
Device ID Local Intf Hold-time Capability Port ID
Total entries displayed: 0
2. LLDP is not enabled.
In both the cases, when issued a SNMP request for the LLDP Neighbor OID, im getting "No such Instance" response.
iso.0.8802.1.1.2.1.4.1.1.7 = No Such Instance currently exists at this OID
Please let me know if i can differentiate the two scenarios. Or, if there's an OID which can tell if LLDP is enabled in a device or not. Because, if the device is not LLDP enabled, i have to make the necessary configuration changes and if the device is enabled with LLDP, i can just ignore.
The devices include wide range of models and thousands of them. Is there a way to identify if LLDP is enabled by any possible means. Please do let me know.
Thanks.
For situation like that, you should look at:
https://cfnng.cisco.com/mibs lldp.JPG
If you can´t find there, then doesn´t exist. But LLDP MIB does exist.
