Archive FTP path '550 Filename invalid' error
Brett Verney
Hi all,
I am attempting to automatically backup a switch configuration to an Filezilla FTP server (Windows) using the the following configuration:
ip ftp source-interface Vlan900
ip ftp username configadmin
ip ftp password 7 xxxxxxxxx
archive
path ftp://192.168.201.50\HQ\$h\$h-$t.bak
write-memory
kron policy-list Config_Backup
cli write memory
cli archive config
kron occurrence Config_Backup at 4:00 Fri recurring
However, both the debugs from the switch and Filezilla server show the following:
May 4 15:42:55.617: FTP: ---> USER configadmin
May 4 15:42:55.619: FTP: 331 Password required for configadmin
May 4 15:42:55.619: FTP: ---> ****
May 4 15:42:55.621: FTP: 230 Logged on
May 4 15:42:55.621: FTP: ---> TYPE I
May 4 15:42:55.623: FTP: 200 Type set to I
May 4 15:42:55.623: FTP: ---> PASV
May 4 15:42:55.626: FTP: 227 Entering Passive Mode (192,168,201,50,10,52)
May 4 15:42:55.628: FTP: ---> STOR HQ/hqtestswitch/hqtestswitch--May--4-15-36-06.753.bak-1
May 4 15:42:55.630: FTP: 550 Filename invalid
May 4 15:42:55.630: FTP: ---> QUIT
May 4 15:42:55.634: FTP: 221 Goodbye
I have also tried:
path ftp://192.168.201.50/HQ/$h/$h-$t.bak
Any ideas?
The switch is a Cat9200  running 17.03.03
Thanks!
-Brett
Mark Elsen
       - Does it work with a manual ftp (tryout) . from the switch ?
 M.
balaji.bandi
check the "/" correct format - try manually first before making use of archieve ?
Format :
  • copy system:running-config ftp: [[[// [username [: password ]@ ]location]/ directory ]/ filename ] or
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/16-9/configuration_guide/sys_mgmt/b_169_sys_mgmt_9200_cg/managing_configuration_files.html#task_gzx_znx_m1b
BB
Hi all,
It seems that there are Windows Server permissions that could not be resolved (outside of my control). I was able to get the server admins to create the directories listed in my config on the server manually in the root directory (/HQ/ for example), and the backups from that point on worked fine.
Thanks for your help
