Are HTTPS probes supported in Cisco devices ?
Arun Srinivasan
Community Member
I am aware Cisco supports HTTP probe types. Are HTTPS (HTTP Secure) probes are supported in Cisco devices too ? If so from which IOS version ?
Your comments are very much appreciated.
Thanks.
AFROJ AHMAD
Hi ,
As per my understanding there is No IOS code which support HTTPS opeartions , Only HTTP operations are supported as of now.
Thakns
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Thakns
Afroz
Vinod Arya
You may try to configure HTTP operation and set port number to 443. but this is not a tested configuration by Cisco. usually works and has limitations.
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Arun Srinivasan
Community Member
Thanks for your responses.
