As a network engineer should I learn Linux or Python
hfakoor222
I'm about to start applications for network engineering positions. I do litigation/cyber fraud forensics.
My SQL skills on a technical level are pretty decent, I have a SQL Expert cert through Oracle, although almost 0 database management experience, however I'm taking a graduate level SQL database enterprise course. I've done machine coding and routines using SQL with VBA in various positions.
As a network engineer I'm wondering if Linux or Python is better. I read that python is good for SD WANs and automation.
However I've recognized Linux can be used in the creation of virtual network functions, or virtual devices. I'm interested in learning network administration (ip addressing, SNMP, building Linux firewalls ~ I'm currently learning and refining skills using freeradius through Ubuntu).  How practical is doing all of this on Linux used in the workplace? I read online they suggest learn Python from several forums, however to me it seems the tasks mentioned above make Linux a valuable skill to have as a network engineer. And maybe the Linux skills could complement SQL in database management or call on the SQL database to be used? However I don't want to learn Linux and not use it. Python from what I've read would be readily applicable in writing various scripts that can automate tasks and be reapplied, which would make my employer appreciate those skillIs.
I do not wanmt to learn both right now.. Rather focus on learning and becoming good t using 1, however its really only worth it if I can apply it in the workplace.
Does any one have advice? Their thoughts or experiences or what either one is used for on a day-to-day or month-to-month use in the workplace?
16 Replies 16
No one knows what will be in demand in 10 years time so if you think like that you may as well do something else but network automation is not going away.
There are lots of free online tutorials for Python etc. but the key thing is to find something that needs automating and then write a script for it because you only really learn how to use a language properly when you are trying to solve a real world issue.
Obviously that doesn't mean run it on production equipment without full testing first.
Jon
hfakoor222
Okay one last question.
I liked Jons idea of thinking of a problem and trying to fix it.
is there any advice to increase my python and Linux skills for network engineering?
Thank you.
