Dante Enabled Managed Switch
tonybalogun
Community Member
Great to be here.
Cisco has supported hugely the spread and success Dante solutions. I understand that the SG300, and SG350 range is Dante enabled. Efficient Electricity Ethernet is a core functionality of these series of switches but is not the best for Dante's operation. Do these managed switch series have the ability to be disabled in their internal features? Can you help show screenshots and how to disable it? Thanks
balaji.bandi
check this thread :
https://community.cisco.com/t5/small-business-switches/sg350-switch-edgeport-on-dante-network/td-p/3793631
BB
tonybalogun
Community Member
This got me more worried about the product SG350. It didn't answer my questions at all.
these are small business switches, unlike enterprise full blown you look may be not worked as expected, as per the message.
what config you have on the ports ? what device you connected to that port ?
BB
Georg Pauwen
have a look at the image attached, I think that is how you can disable EEE:
