ASA and SNMPv3
patrias
LMS 3.2.1 and ASA 5510 configured for SNMPv3 access,
Inventory and Config sync works, so i think SNMPv3 must work,
but a credential check says SNMPv3 is not supported,
Device Packages are updated,
best regards
Alex
Joe Clarke
You're currently seeing the results of CSCtd67173.  SNMPv3 support on the ASA is limited in that read-write support is not available.  Therefore, LMS will report "Not supported."  This is expected.  All SNMPv3 read-only collection operations will work in LMS 3.2.1, however.
thanks
