ASA Priviledges level required
bilal-siddiqui
Please let me know the privilege level that is required to Cisco ASA user to executed this command.
  • show crypto key mypubkey rsa
  • show interface | include up.* +up
  • show interface ip brief | in __down
  • show run | include \*
  • show run aaa accounting
  • show run class-map
  • show run dynamic-filter
  • show run password-policy
  • show run policy-map
  • show run service-policy
  • show running-config
  • show running-config | include ^ip
  • show running-config | include access-group
  • show running-config | include access-list
  • show running-config | include ntp authenticate
  • show running-config | include ntp authentication-key
  • show running-config | include ntp server
  • show running-config | include ntp trusted-key
  • show running-config aaa-server
  • show running-config interface
  • show running-config router
  • show snmp user
  • show snmp-server group | include groupname
  • show version | include Software_Version
    Your participation is much helpful to me
    regards,
@bilal-siddiqui
show command does not requires any privilege, you just need to have access to the device. By default, if you create an user and not specify privilege it will have privilege of 2 ,  which should be enough to run show commands.
https://www.cisco.com/c/en/us/td/docs/security/asa/asa96/configuration/general/asa-96-general-config/admin-management.html
You want some user to do only show?
Can I see config of aaa ?
MHM
