ASA sending Netflow to a netflow receiver at port 2055
lchance
I'm not receiving netflow traffic from our ASA 5540 which we consider being correctly configured for this.
Does the ASA require a Loopback interface be created for sourcing netflow? We have not tried that.
Or does it require sources from the Inside or something else we are missing? Thanks.
shmcguir
You may want to have a look at the netflow configuration example  for ASA here:
https://supportforums.cisco.com/docs/DOC-6113#CLI
I think this should cover everything for you.
Cheers,
Shane
