ASA5505 ASDM - How do you configure the default gateway for a WAN interface?
DanielMHussey
Hello-
I see the abilit to specify a static IP and the subnet mask, however, there is no method to configure the default gateway.  This is causing the WAN interface to no be able to reach the internet.
-Dan
Marvin Rhoads
Add a route for 0.0.0.0 0.0.0.0 (= "any" in the GUI) to the outside interface. That is done in Configuration, Device Setup, Routing.
See the screen shot below, taken from an ASDM instance running in demo mode:
