ASDM not loading properly
tocckvolpi
I cannot get ASDM to come up.  I get to the Screen that tells me that it will start in another window, and the bar goes across to 100% and it says "Please wait...main window is coming up.."  But it doesn't come up. It just sits there.  I've tried in on a windows 7 64 bit machine.. and on a  virtual 32 bit XP machine and it does the same thing... my ASDM version is 5.0(8) and my ASA Version is 7.0(8) so those are compatible.  Any suggestions??
Thanks in advance.
Karla
Marvin Rhoads
As a Java application, an old ASDM won't work well with a new(ish) Java. Per the ASDM 5.0(8) release notes, it requires Java versions 1.4(2), 5 or 6.
I'd unistall JAva completely on your 32-bit XP VM and then install a "fresh" archive version.
