asic
amisu
hi,
looking for snmp or other way to check the utilization of asic on 6500 module.
i.e - if i am over utilized 4 giga ports on blocking module such as 6148, i would like to monitor it or to notify it (maybe with trap) when it passed the 1G barrier.
thanks
yjdabear
You may have come across this document already:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801751d7.shtml#ASIC
It looks to me that the most feasible approach is to write a custom script (with the "expect" scripting language, for example) to keep tabs on the buffer overruns (or qos3Outlost on Native IOS) from the CLI. What the Cisco link doesn't say is, on the CatOS at least, you'd need [to write the script] to determine what "PORT" ASIC each module is using with "show asic slot #" in enable mode. For example:
CatOSCat6500 (enable) show asic slot 2
Forwarding engine version : 3
Shortcut engine version : 1
Central rewrite engine version : 0
Asic Name Count Major Version Minor Version Asic Type
pinnacle 1 2 0 PORT
medusa 1 2 0 FABRIC-BUS
titan 1 0 1 REPLICATION
But sometimes, it doesn't show which ASIC is what:
Module in slot 2 has 3 type(s) of ASICs
ASIC Name Count Version
PINNACLE 1 (2.0)
MEDUSA 1 (2.0)
TITAN 1 (0.1)
Then you look for non-zero values in the following output:
CatOSCat6500 (enable) show asicreg errcounters
NativeIOSCat6500# show counters interface gigabitEthernet | include qos3Outlost"
thank you - this hint let me found the snmp option -- 1.3.6.1.2.1.2.2.1.19
Ami
