Ask a Question
My Name Is Bobi
1.In the attached scenario where the servers are located?
2.Which switches should vlan routing perform?
3.What form and protocol should be used for routing?
Thanks for taking the time to answer my questions
Martin L
1. Distribution is good place
2.  Distribution and Core
3. OSPF, EIGRP,
kubn2
1. It depends. If server should be available only for single vlan then I would connect it to access layer. If servers should be available for multiple vlans I would connect it to distribution layer.
2. Distribution layer
3. It depends on you. 2 Most popular protocols are OSPF and EIGRP.
Martin L
3. OSPF, EIGRP,
