02-16-2016 01:58 AM
Dears,
I need help to understand the AR 1000 licenses.
1) What is the main advantage of the IPSec license (FLASR1-IPSEC-RTU), can the Encryption work without it?
2) I have understood that ordering a Cisco ASR 1000 Advanced IP Services License (ASR SLASR1-AIS) should have the encryption enabled, if this is correct, why i need to purchase the IPSec license?
3) what is the difference between the Advanced IP Service and Advanced Enterprise Service licences ? Cisco only specifies that the AIS is same to AES but doesn't include "older protocols?
4) I have understood that RTU license is embedded in the Router, does this means that accepting EULA will enable it, but for example if i didn't purchase the IPSec license and then accept the EULA, it will be an evaluation license what will happen when the evaluation period finish?
Muhannad
Solved! Go to Solution.
02-17-2016 12:11 AM
IP Services includes the lPSec licence. Buy it again would leave you with two copies of it. A waste of money.
02-16-2016 04:47 PM
1. Enables IPSec VPN support.
2. As I understand it, Advanced IP Services includes the IPSec licence above.
3. As I understand it, adds support for protocols you wont see any more, like DECNET, etc. They are legacy protocols.
4. When the evaluation runs out those features stop working.
Check out this licence feature comparison.
02-16-2016 11:38 PM
Dear Philip,
Thanks for your response.
I am still confused regarding the following:
If i have purchased the Cisco ASR 1000 Series RP1/2 Advanced IP Services which includes all features, do i still need to purchase the IPSec license if i need to configure VPN in my ASR Routers?
I have understood from the following that after selecting the suitable IOS XE, i should add the required software license of this feature, which mean that i should add the IPSec license:
First, select a Cisco IOS XE Software consolidated package that supports the required features. Second, check whether this feature requires a software license. If it does, you must purchase the required license in addition to the Cisco IOS XE consolidated package. The consolidated package and license are linked to the chassis.
Please let me know if i am understaning the issue correctly or not?
Muhannad
02-16-2016 11:59 PM
Correct, you do not need to buy an IPSec licence.
02-17-2016 12:06 AM
Dear Philip,
Ref to Cisco Documnetations:
Which mean i should purchase the IPSec license along with the IP services IOS XS, this is what i have understood?
Muhannad
02-17-2016 12:11 AM
02-21-2016 01:11 AM
Thanks Philip,
You made it clear for me.
I think I have left with only one question:
We only need the IPsec license if we are having IP base software, correct?
Muhannad
02-21-2016 10:56 AM
If you have IP Base then yes, you need to buy the IPSec licence.
03-21-2016 09:09 AM
This is incorrect. You still need the IPSec license in addition to IP Services or Enterprise Services to use 3DES or AES encryption.
The following is an up to date ordering guide:
http://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/guide-c07-731639.html
Example 13 is for a secure WAN router. It needs an advanced IOS feature set, IPSec license and a firewall license.
Most ASR1k licenses are honor-based so are not enforced by the router however you need to purchase licenses for the features you use to be compliant.
06-08-2018 06:54 AM
04-28-2019 07:35 PM
Cisco licensing is so confusing !! Anyway, I'm after the following:
Any recommendation for me @ugot2nome ?
04-30-2019 06:01 AM
The IOS is Universal but you will need the Advanced Enterprise License to turn on some of the Service Provider functionalities along with the RTU entitlement licenses. In the above linked document - see Example 5 and Table 23 as an example but some of these are platform specific. Bottom line - identify number of 1/10GB ports, features needed and then size the box appropriately.
The safest bet is to open a Cisco TAC support ticket and route it to the License group with your questions.
11-28-2017 03:33 AM
Hi, I noticed that "No Systems Network Architecture (SNA) switching" (DLSW) is listed as not support in any ASR Technology package, IP Base, AIS or AES. Is DLSW just not supported, or is an additional feature license needed (with any of the 3 technology packages?), if so which one.
Mick Russell
04-10-2019 02:26 PM
Leaving this here in case someone else runs into the same issue as me.
Concerning the RTU and EULA acceptance, I ran into an odd issue with IWAN when adding a site.
APIC didn't accept my ASR router being added into IWAN inventory at first. It gave a warning about ipsec license not being present. I made sure all the 'license boot level' type commands were in there. No PAK file to install, so that wasn't needed. What did it was the 'license right-to-use move ipsec' command. It complained about EULA not being accepted, but the 'license accept end user agreement' command didn't do anything. APIC let me go ahead and add the router and then provision it as normal, anyway. SUCCESS!
>enable
#license right-to-use move <feature_name>
07-18-2019 02:27 PM - edited 07-18-2019 02:28 PM
The answer marked solved above is incorrect as others have noted. The IP Services image does include the IPSec encryption features. But you still need to purchase the FLASR1-IPSEC-RTU license in order to USE it.
In short you must purchase IP Services + IPSec-RTU.
Hope that helps.
