06-18-2020 01:14 AM
I have an ASR 1001-X (Bandwidth throughput is 20Gbps), incoming from WAN link (uplink) is 2 x 10Gbps connected into 2x10GE port.
so, my concern is whether this router is good enough to support?
Solved! Go to Solution.
06-18-2020 07:43 PM
06-18-2020 01:30 AM
That will depend on the license enabled.
Post the complete output to the following commands:
sh license feature sh platform hardware throughput level
06-18-2020 01:35 AM
The license enable is 20Gbps.
total performance bandwidth need to calculate in downlink ports as well? or just refer to uplink ports with total bandwidth?
you can refer to my design in my post.
06-18-2020 03:22 AM
06-18-2020 06:15 PM
Dear Leo,
As per requested.
Appreciated your expertise comment.
06-18-2020 07:43 PM
06-18-2020 10:25 PM
Thanks Leo. Appreciated.
08-05-2020 12:24 AM
Based on this design, i need to add 1 more unit of license to cater 40Gbps throughput. because this design is Full Duplex. @Leo Laohoo
