ASR 1001-X multiple CPU oids
paul amaral
Level 4
Level 4
Hi I'm trying to monitor the different CPUs on an ASR 1001-x but so far i can only seem to monitor the RP. I have followed the document on cisco asr oids
It indicates the following,
SNMP OID to Monitor RP/ESP/SIP CPU Utilization
ASR1K#show platform software status control-processor brief | section Load
Load Average
Slot      Status        1-Min   5-Min      15-Min
RP0      Healthy        0.75    0.47        0.41
ESP0     Healthy        0.00    0.00        0.00
SIP0     Healthy        0.00    0.00        0.00
It corresponds to:
1.3.6.1.4.1.9.9.109.1.1.1.1.24.2 = Gauge32: 75  -- 1 min RP0
1.3.6.1.4.1.9.9.109.1.1.1.1.24.3 = Gauge32: 0  -- 1 min ESP0
1.3.6.1.4.1.9.9.109.1.1.1.1.24.4 = Gauge32: 0  -- 1 min SIP0
1.3.6.1.4.1.9.9.109.1.1.1.1.25.2 = Gauge32: 47  -- 5 min RP0
1.3.6.1.4.1.9.9.109.1.1.1.1.25.3 = Gauge32: 0   -- 5 min ESP0
1.3.6.1.4.1.9.9.109.1.1.1.1.25.4 = Gauge32: 0  -- 5 min SIP0
1.3.6.1.4.1.9.9.109.1.1.1.1.26.2 = Gauge32: 41  -- 15 min RP0
1.3.6.1.4.1.9.9.109.1.1.1.1.26.3 = Gauge32: 0  -- 15 min ESP0
1.3.6.1.4.1.9.9.109.1.1.1.1.26.4 = Gauge32: 0   -- 15 min SIP0
However the above command on the ASR 1001-x does show the ESP. Also from the OIDs listed  1.3.6.1.4.1.9.9.109.1.1.1.1.24 25 and 26 work and display the 1 min 5 min and 15 min RP load.
Does anyone know the OIDs for the ESP and QFP ?
TIA, Paul
Giuseppe Larosa
Hello Paul,
you are using the Cisco process MIB
you can find the MIB definition here
ftp://ftp.cisco.com/pub/mibs/v2/CISCO-PROCESS-MIB.my
The MIB is not updated since 2011.
it is declared to be supported and verified on ASR 1000 at the following link
ftp://ftp.cisco.com/pub/mibs/supportlists/asr1000/asr1000-supportlist.html#_Supported_and_Verified
Hope to help
Giuseppe
Guiseppe, you are always busy replying lol.
To be honest with you i dont even know what do do with that file, do I uploaded to the router, if so were do i put it, or is that just for reference ?
I was actually able to find the QFP load its OID ..1.3.6.1.4.1.9.9.715.1.1.6.1.14.9026  RP is OID .1.3.6.1.4.1.9.9.109.1.1.1.1.24/25/26 now i just need ESP/FECP
thanks Paul
Hello Paul,
Just for reference, the router has already the MIB "on board".
The OID you have found for QFP is in CISCO-ENTITY-QFP-MIB.
I will go to sleep now I promise :)
Hope to help
Giuseppe
