Cisco 2960X POE Switch- No Power on Switch
Mubasshir
I have a Cisco 2960X PoE Switch, But there is an issue with Power on few ports. When I executed "show power inline" command. Oper status is "off" for all ports. Any solution would be apperciated.
18 Replies 18
balaji.bandi
Can you post output of both show version, show power inline
Looks at PoE Diagnosis
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/g_power_over_ethernet.html
BB
Leo Laohoo
Can you also post the complete output to the command "sh post"?
Switch#sh post
Stored system POST messages:
Switch 1
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : MAC Loopback Passed
POST: EMAC Loopback Tests : PHY Loopback Passed
POST: EMAC Loopback Tests : End, Status Passed
You have not posted the information request earlier post. both show version, show power inline
BB
Show power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 740.0 0.0 740.0
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/1 auto off 0.0 n/a n/a 30.0
Gi1/0/2 auto off 0.0 n/a n/a 30.0
Gi1/0/3 auto off 0.0 n/a n/a 30.0
Gi1/0/4 auto off 0.0 n/a n/a 30.0
Gi1/0/5 auto off 0.0 n/a n/a 30.0
Gi1/0/6 auto off 0.0 n/a n/a 30.0
Gi1/0/7 auto off 0.0 n/a n/a 30.0
Gi1/0/8 auto off 0.0 n/a n/a 30.0
Gi1/0/9 auto off 0.0 n/a n/a 30.0
Gi1/0/10 auto off 0.0 n/a n/a 30.0
Gi1/0/11 auto off 0.0 n/a n/a 30.0
Gi1/0/12 auto off 0.0 n/a n/a 30.0
Gi1/0/13 auto off 0.0 n/a n/a 30.0
Gi1/0/14 auto off 0.0 n/a n/a 30.0
Gi1/0/15 auto off 0.0 n/a n/a 30.0
Gi1/0/16 auto off 0.0 n/a n/a 30.0
Gi1/0/17 auto off 0.0 n/a n/a 30.0
Gi1/0/18 auto off 0.0 n/a n/a 30.0
Gi1/0/19 auto off 0.0 n/a n/a 30.0
Gi1/0/20 auto off 0.0 n/a n/a 30.0
Gi1/0/21 auto off 0.0 n/a n/a 30.0
Gi1/0/22 auto off 0.0 n/a n/a 30.0
Gi1/0/23 auto off 0.0 n/a n/a 30.0
Gi1/0/24 auto off 0.0 n/a n/a 30.0
Gi1/0/25 auto off 0.0 n/a n/a 30.0
Gi1/0/26 auto off 0.0 n/a n/a 30.0
Gi1/0/27 auto off 0.0 n/a n/a 30.0
(Watts)
Gi1/0/28 auto off 0.0 n/a n/a 30.0
Gi1/0/29 auto off 0.0 n/a n/a 30.0
Gi1/0/30 auto off 0.0 n/a n/a 30.0
Gi1/0/31 auto off 0.0 n/a n/a 30.0
Gi1/0/32 auto off 0.0 n/a n/a 30.0
Gi1/0/33 auto off 0.0 n/a n/a 30.0
Gi1/0/34 auto off 0.0 n/a n/a 30.0
Gi1/0/35 auto off 0.0 n/a n/a 30.0
Gi1/0/36 auto off 0.0 n/a n/a 30.0
Gi1/0/37 auto off 0.0 n/a n/a 30.0
Gi1/0/38 auto off 0.0 n/a n/a 30.0
Gi1/0/39 auto off 0.0 n/a n/a 30.0
Gi1/0/40 auto off 0.0 n/a n/a 30.0
Gi1/0/41 auto off 0.0 n/a n/a 30.0
Gi1/0/42 auto off 0.0 n/a n/a 30.0
Gi1/0/43 auto off 0.0 n/a n/a 30.0
Gi1/0/44 auto off 0.0 n/a n/a 30.0
Gi1/0/45 auto off 0.0 n/a n/a 30.0
Gi1/0/46 auto off 0.0 n/a n/a 30.0
Gi1/0/47 auto off 0.0 n/a n/a 30.0
Gi1/0/48 auto off 0.0 n/a n/a 30.0
Show version
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(4)E7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 18-Sep-18 13:07 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(3r)E1, RELEASE SOFTWARE (fc1)
GSS-MDF-4FL-CoreSW01 uptime is 18 hours, 33 minutes
System restarted at 01:01:06 pk Tue Apr 23 2019
System image file is "flash:c2960x-universalk9-mz.152-4.E7.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-48FPD-L (APM86XXX) processor (revision M0) with 524288K bytes of memory.
Processor board ID FCW2009A1BL
Last reset from reload command
2 Virtual Ethernet interfaces
1 FastEthernet interface
50 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 50:08:AC:7F:7C:80
Motherboard assembly number : 73-16693-05
Power supply part number : 341-0537-02
Motherboard serial number : FOC2136E77J
Power supply serial number : DCB2020IK8
Model revision number : M0
Motherboard revision number : A0
Model number : WS-C2960X-48FPD-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC2100E36U
System serial number : FCW2009A1BL
Top Assembly Part Number : 68-100471-02
Top Assembly Revision Number : A0
Version ID : V05
CLEI Code Number : CMMLJ00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960X-48FPD-L 15.2(4)E7 C2960X-UNIVERSALK9-M
Configuration register is 0xF
I don't see anything wrong.
Oper status is "Off" means there is no PoE devices attached to the port.
Here is port status after connecting POE Camera. Error msg already shared above
Sh int status
Gi1/0/43 Link-to-CCTV connected 206 a-full a-100 10/100/1000BaseTX
Sh Power inline
1 740.0 0.0 740.0
So the CCTV camera has a link up but it's not pulling power from the switch. Maybe the CCTV camera doesn't support PoE?
CCTV camera supported POE, same model is also working on other switches.
Do the following commands:
1. Command: test cable tdr inteface Gi1/0/43;
2. Wait for approximately 5 to 7 seconds;
3. Command: show cable tdr inteface Gi1/0/43; and
4. Post the complete output to #3.
TDR test last run on: April 24 22:33:45
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/43 auto Pair A 52 +/- 10 meters N/A Open
Pair B 52 +/- 10 meters N/A Open
Pair C 50 +/- 10 meters N/A Open
Pair D 50 +/- 10 meters N/A Open
The output to the TDR doesn't make any sense.
Output shows that NOTHING is connected to port Gi 1/0/43 but in your previous response it shows a something is connected to the port.
this log is taking when is cennected
this log is taking when PD is connected
