ASR-9K (vrf and management interface)
sendalot7
I see that regular IOS & NX-OS & ASR(IOS-XE) have different ways of setting out-of-band management interface.
Below is brief config.
I can ping my immediate default gw but can't ping anything outside of my vlan/subnet.
Help appreciated, thanks!
RP/0/RSP0/CPU0:ios#show run
Tue Apr  4 16:17:55.079 UTC
Building configuration...
!! IOS XR Configuration 5.3.3
!! Last configuration change at Tue Apr  4 15:58:22 2017 by admin
vrf mgmt
interface MgmtEth0/RSP0/CPU0/0
 ipv4 address 10.7.0.38 255.255.255.0
interface MgmtEth0/RSP0/CPU0/1
 shutdown
router static
 address-family ipv4 unicast
  0.0.0.0/8 10.7.0.1
 vrf mgmt
   0.0.0.0/0 10.7.0.1
Steven Larson
This is how I have mine setup:
vrf MGMT
description Management
import route-target
200:200
export route-target
200:200
description MGMT
vrf MGMT
ipv4 address 10.1.2.111 255.255.255.0
load-interval 30
router static
vrf MGMT
0.0.0.0/0 10.1.2.1
I just tested and this works.
Harold Ritter
Hi @sendalot7 ,
The mgmt interface is in the global and the default route in the global is wrong (0.0.0.0/8 instead of 0.0.0.0/0), hence it is not working. The best thing would be to put the mgmt interface in the mgmt vrf. You already have the proper default static route in vrf mgmt.
vrf mgmt
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
