Showing results forĀ
Search instead forĀ
Did you mean:Ā
ASR1002 Parser view problem
tan2
The parser view cannot configure command for classmap/policymap configuration mode
tan2
I am using the ASR1002 , the IOS version is Cisco IOS XE Software, Version 03.16.06.S
I configured the parser view to assign the commands to specific users .
1. Example :
                  parser view xxx
                   commands policymap-service include all class
But after I finished th configuration , show run cannot see this configuration . And when user log in the parser view,
they cannot execute the class command under policymap configuration mode .
2. How can I configure the command under parser view to enable all the commands of class-map configuration mode .
     I have several class-map configured as below:
               class-map xxx
                 match access-group name yyy
      And configured the parser view as below:
               commands traffic-class-map  include all  match
           Then login the parser view , but the match command isn't configurable under the class-map configuration mode . So how should I configure the parser view for class-map configuration mode .
Thanks .
I am not using XE, so I am not sure if the keywords are the same, but try the below:
aaa new-model
parser view xxx inclusive
secret 5 $1$FAvg$zBPJidcjPPFLMx5s58L191
commands cpf-policymap include all class
commands exec include configure terminal
aaa new-model
commands cpf-classmap include all match
The IOS which I am using doesn't support the commands you mentioned . Thanks .
