Authenticate NCS 1.0 Login vs. ACS 5.3
Kai Onken
I'm trying to manages the NCS WebGUI users via ACS 5.3. When I try to login with my user "TESTUSER" I'll receivce the following message:
"No authorization information found for Remote Authenticated User. Please check the correctness of the associated task(s) and Virtual Domain(s) in the remote server"
At the NCS Server I've configured:
1.
Administration > AAA > TACACS+ Servers = Added Tacacs Server 1
Administration > AAA > TACACS+ Servers = Added Tacacs Server 2
2.
Administration > AAA > AAA Mode Settings = Tacacs+
Enable fallback to Local - on auth failure or no server response is checked
--- !! ACS and NCS are in the same subnet !! ---
At the ACS Server I've configure
1.
Users and Identity Stores > Internal Identity Stores > Users = TESTUSER + Password = abcd1234ABCD + Member of NCS-ADMIN
2.
Network Resources > Network Devices and AAA Clients = Added NCS with vaild Tacacs key
3.
Access Policies > Access Services = Name: AS LOGIN TACACS - Service Type: Device Administration - Included Policies: Identity & Authorization
4.
Access Policies > Access Services > Service Selection Rules = Name: EnabledSSR-Rule-1 && NDG:Device Type: -ANY- && NDG:Location: -ANY-  && match Tacacs > AS LOGIN TACACS
5.
Access Policies > Access Services > AS LOGIN TACACS > Identity = Internal Users
6.
Policy Elements > Authorization and Permissions  > Device Administration > Shell Profiles: NCS-ADMIN-LOGIN > Custom attributes
     role0=Root
     virtual-domain0=ROOT-DOMAIN
     task0=Users and Groups
     task1=Audit Trails
     task2=TACACS+ Servers
     task3=RADIUS Servers
     task4=Logging
     task5=License Center
     task6=Scheduled Tasks and Data Collection
     task7=User Preferences
     task8=System Settings
     task9=Diagnostic Information
     task10=View Alerts and Events
     task11=Email Notification
     task12=Delete and Clear Alerts
     task13=Pick and Unpick Alerts
     task14=Configure Controllers
     task15=Configure Templates
     task16=Configure Config Groups
     task17=Configure Access Points
     task18=Configure Access Point Templates
     task19=Configure Choke Points
     task20=Monitor Controllers
     task21=Monitor Access Points
     task22=Monitor Clients
     task23=Monitor Tags
     task24=Monitor Security
     task25=Monitor Chokepoints
     task26=Mesh Reports
     task27=Client Reports
     task28=Performance Reports
     task29=Security Reports
     task30=Location Server Management
     task31=View Location Notifications
     task32=Maps Read Only
     task33=Maps Read Write
     task34=Client Location
     task35=Rogue Location
     task36=Planning Mode
     task37=Ack and Unack Alerts
     task38=Migration Templates
     task39=Configure Spectrum Experts
     task40=Monitor Spectrum Experts
     task41=Auto Provisioning
     task42=Voice Audit Report
     task43=Virtual Domain Management
     task44=Scheduled Configuration Tasks
     task45=Configure WiFi TDOA Receivers
     task46=Configure ACS View Servers
     task47=Monitor WiFi TDOA Receivers
     task48=RRM Dashboard
     task49=Config Audit Dashboard
     task50=High Availability Configuration
     task51=Health Monitor Details
     task52=Configure WIPS Profiles
     task53=Global SSID Groups
     task54=Configure Lightweight Access Point Templates
     task55=Configure Autonomous Access Point Templates
     task56=Handover Server Management
     task57=Monitor Handover Server
     task58=Configure Ethernet Switch Ports
     task59=Configure Ethernet Switches
     task60=Device Reports
     task61=Network Summary Reports
     task62=Compliance Reports
     task63=Report Launch Pad
     task64=Run Reports List
     task65=Saved Reports List
     task66=Report Run History
     task67=Database Query and Update
     task68=Ack and Unack Security Index Issues
     task69=View Security Index Issues
     task70=Monitor Media Streams
     task71=Monitor Interferers
     task72=Voice Diagnostics
     task73=CleanAir Reports
     task74=ContextAware Reports
     task75=Automated Feedback
     task76=TAC Case Attachment Tool
7.
Access Policies > Access Services > AS LOGIN TACACS > Authorization =
rule-1   NDG:Device Type: -ANY- && NDG:Location: -ANY- && Identity Group: in All Groups:NCS-ADMIN && Shell Profile: NCS-ADMIN-LOGIN
9 Replies 9
zsmaray
The symtom was the same then I put the virtual-domain row to the end. After that I coud login to the NCS using my tacacs+ account.
I've solved the first step with this document. The main problem was the virtual-domain numbering.
https://supportforums.cisco.com/docs/DOC-17909
Now in second step, I would like to know if I can also define, whitch building, floor, etc. is only allowed.
I had the same problem trying to authenticate NCS through ACS5.3 via TACACS but fixed it using the top post.
"The symtom was the same then I put the virtual-domain row to the end. After that I coud login to the NCS using my tacacs+ account."
can you give me a hint?
my virtual-domain is currently "ROOT-DOMAIN", so I put username as "ROOT-DOMAIN/steve" but no luck.
I am not using ACS, but TACACS.net software, which is working great with switch and router so far.
But only PI can't add to TACACS.
Could you try this procedure :
(1)  Open the URL after login into PI - https:///webacs/ncsDiag.do?
(2)  Click on "DB Update
(3) Run the Following Query - DELETE FROM wcspreference WHERE key='defaultPartition'
(4)restart the PI.
Hi everybody
I had the same issue, after migration from wcs 7.0 to ncs 1.1, uprade to PI 1.3, TACACS+ did not work, I always got this message:
ACS 5.3 was set up properly (it did work with WCS).
After applying th above procedure, TACACS+ login now works.
Thanks Paul
Daniel
I'm having the same issue with tacacs.net.  It works great with routers/switches, but I can't get the authorization piece to work for NCS.  I tried the virtual-domain at the top of the list and the bottom, but neither worked.  Anyone have a solution?
Prime Infrastructure 1.2 (Old CiscoWork, LMS, NCS) authentication through TACACS.net: In order for PI to authenticate through TACACS, vendor specific attribute needs to be added in TACACS  (or RADIUS) There are two attributes that TACACS (or RADIUS) should have. (virtual-domain / role) Unfortunately, I couldn't find out how to add those two attributes in TACACS, but definitely below section is for VSAs. I used alternative solution for PI with RADIUS which we already have for wireless access.
Good luck for your search. If you find syntax, let me know.
Ben Meagher
I had the same output after doing a backup/restore to a new VM. I had to update the tacacs server ip.
Administration  ->   Users, Roles, & AAA  ->  TACACS
     Local Interface IP
