AUTOMATIC BAKCUP OF CISCO DEVICES VIA ANSIBLE
felix.mugambi
Hello Team,
Hope you are all well.
I have this challenge when i try to run a playbook to back up network devices.
am attaching the playbook config and the error.
- name: AUTOMATIC BACKUP OF RUNNING-CONFIG
hosts: Core_Switch
gather_facts: true
connection: local
tasks:
- name: DISPLAYING THE RUNNING-CONFIG
ios_command:
commands:
- show run
timeout: 30
host: "{{ ansible_host }}"
username: xxxxx
password: yyyyy
register: config
- name: Get Current Date
local_action: command date +%Y-%b-%d
register: date
- name: Get Current Time
local_action: command date +%H:%M
register: time
- name: save Output to /home/user1/Backups
copy:
content: "{{ config.stdout[0] }}"
dest: "/home/user1/Backups/_{{ date.stdout }}_at_{{ time.stdout }}-{{ inventory_hostname }}.txt"
Error is as below :-
7 Replies 7
You have connection: local, which is meant for tasks executed on the Ansible control machine itself.
Update the connection line to specify a connection type suitable for network devices.
connection: network_cli
I would also set the ansible_network_os variable to cisco.ios.ios to ensure Ansible uses the correct libraries.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Here the error am now getting.
Torbjørn
You seem to be missing the paramiko python module. It can be installed using pip, likely with the command "python3 -m pip install paramiko" depending on your OS.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
This could be one of two things based on the error incorrect credential and/or you are missing ansible-pylibssh library (pip install this)
Hope this helps.
Credentials are ok, since they can ssh to the device, Installed the library as well.
Anything else I might be missing?
can you run this with -vvvv and share the output, the only thing the last error is showing is the wrong creds, this will giev a more verbose output that might include additional details about the authentication failure in the error, also can you share the  inventory file too?
