Backup restoration problem
vaibhav-g
Hi Team
we are not able to restore backup.
plse find the logs and provide the solution.
Vaibhav
8 Replies 8
Joe Clarke
On what version of LMS are you restoring?
LMS version 2.6
Regrads
Vaibhav
Not applicable
This looks like CSCsd65579 which is fixed in Common Services 3.0.6.
Not applicable
Hi Clark
Thanks for the reply
could you share the BUG details of the same.
Vaibhav
This is an internal bug. The problem occurs when path components contain spaces as they do in your case.
Vaibhav
