Bad address problem (cisco RV345 router)
We have four rv345 routers and each router has a VPN connected.
We have a problem only one router. I uploaded  file the log message.
What is the problem ?
How do I solve it.
Richard Burts
There are lots of very odd log messages. I do not have much experience with the RV345 and if someone in the community does have experience with this I hope they will jump in. But it looks to me like the config file for this router has become corrupted. Is it possible to boot this router without using startup config (typically done for password recovery)? If so can you look at the existing startup config? Do you have a backup of the configuration of this router? If so can you try booting the router using the backup config file? Or boot the router with a config file from a working router?
Rick
nagrajk1969
The "dnsmasq" is used primarily as the dhcp-server on this router. So check in your dhcp-server config settings (for each of the vlanX you have configured on this router). There maybe a manually entered/configured setting that is not being accepted...is there any lease reservation config applied by you in the dhcp-server.....????...something like that
