04-03-2019 06:07 PM
Want to understand the bandwidth allocation in the switching/routing environment. How bandwidth allocation happen in the network.
Suppose we have 2 L2 switches having 48 -1G ports , L3 Switch having 24- 1G ports, Router having 2 -1G ports. and we connect 8 users. 4 users connected with L2 SW1 and Other 4 with L2 Sw2. Both L2 connected with L3 SW and Then Router. Users Pc's has 1G NIC.
All ports are 1G end-to-end. Want to understand the bandwidth allocations on PC, Sw level. Can someone help and provide the clarity
04-03-2019 06:51 PM - edited 04-03-2019 06:53 PM
Can you please explain what is the reason for bandwidth allocation for each port. if they are same users in the coporate lan, if you bandwidth limitaiton on edge, then there is no point to have 1GB connection to end note, you could by 100MB or less.
As per best practice, LAN or enterprise network have locally can communicate using 1GB in your case.
If you want to control the bandwidth - i would suggest to interface facing to internet side.
Like mentioned in this example Guide :
https://www.howtogeek.com/75660/the-beginners-guide-to-qos-on-your-router/
Make sense ? if this is not the case, please explain use case for better understanding.
=====️ Preenayamo Vasudevam ️=====
04-03-2019 08:23 PM
